跳转到主内容
任天堂 Game Boy的彩色版本,发布于1998年。 维修Game Boy Color十分容易。
74 个问题 查看全部
Game shark and Pokemon silver
I used game shark on my Pokémon silver and at first it was working perfectly got unlimited master ball and the first Pokémon code I put in worked caught it saved and hit button on game shark to go back to gameshark menu and put different Pokémon catch code in and once I tried going back to the actual game the screen just went blank(white)
so I turned off consol took game out of the gameshark and tried just the game without the gameshark and now it’s just white and game will not work at all….
any ideas on how to fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
It’s not tht the game won’t save its the whole game won’t even work doesn’t even get pass the start up screen it’s does the Nintendo start up screen then just goes blank
完成的
@vactac101 See my update.
完成的
添加一条评论
1个答案
最有帮助的答案
The problem with devices like the Game Shark is they do mess up save files beyond repair if you use conflicting codes - generally, once you damage the save there’s not much you can do but start over. Pro tip: Have two saves when you use cheat codes.
If the game doesn’t want to load, the save you did it on is so corrupt it cannot boot. Refer to this guide to open the cartridge, remove the battery and replace it. Run it without the battery to be sure the saves are gone. However, it may be possible to erase the saves by doing it before the game loads.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John vac 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 32
总计 878
