跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
1 inch from left side not responding after installing new digitizer
i installed a new touch screen digitizer and for some reason about 1 inch from the left side of the screen there is no touch response at all is there a fix to this ? i bought a zentop digitizer for my a1822 ipad
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
This is my second screen that has had this issue my connectors look fine. Can it be the screens im getting are bad? Should i try the ifix it brand of digitizers?
完成的
添加一条评论
2个答案
It sounds like you have a defective part.
这个答案有帮助吗?
得分 0
1条评论:
This is most likely the case. OP try reseating the digitiser connectors on the board and see if that helps.
The other thing to note is that there is a peel for the adhesive on the digitiser cable that sticks that cable to the glass like the original screen has.
完成的
添加一条评论
Same product, same problem here
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
