跳转到主内容
These repair guides are for a 2007-2012 Jeep Wrangler (JK) Sport, Sahara, Rubicon and Unlimited Editions.
22 个问题 查看全部
Is there a way to check if my engine is getting fuel?
I can hear the fuel pump running but I’m not sure if I’m getting fuel to my motor. How do I check
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It might have a fuel pressure test port in the line. If it doesn't you will have to unhook the line and put a fuel gauge in the line. Shops carry those sets but they run in the hundreds of dollars. If it has a test port you should be able to rent one from autozone, o'Reilly's, etc. You should also verify that you have spark.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cody Craig 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 258
