跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
Why won't my truck stay running
I've replaced the ignition pick up, cap and rotor on the distributor, ignition coil, i did a tune up and it ran fine for a while and I let it sit a couple days and now when I when to start it, it acted like it started but as soon as I released pressure from the key it dies. I think its the ignition switch, but it looks fine and I'm not 110% on it, any advice helps.
Update (06/29/2020)
Alright now I replaced the ignition switch, and I'm still having the same problem. And I kinda inspected the wire harness and it seems fine wires look good. So now I'm puzzled.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's the ignition switch. You are losing the ignition signal when in the run position. It will stay running if you hold it in the start position. Make sure you replace the ignition switch on the steering column not the key and tumbler.
Update (09/17/2020)
Did you replace the key and tumbler or the electrical part on the switch?
这个答案有帮助吗?
得分 0
3条评论:
Thats exactly what its doin, thank ya , I was either leaning toward that or a fusible link gone bad.
完成的
Definitely the ignition switch.
完成的
You may need to check he ignition switch throw to make sure it is adjusted Sense you replaced the switch already and still have the same issue if you got a test light you should be able to see it is getting power in the run position or there maybe a wire issue
完成的
添加一条评论
添加你的答案
Dalton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 574
