跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Blade SSD is about to failure on my iMac 27''Late 2015. Need some help
Hello all.
I have an late 2015 27” iMac - I7 4.0 GHz + 3TB Fusion Drive (with 128GB Blade SSD).
Running DriverDX, it shows that the lifetime of my SSD is kind of critical
Should I be really worried about it ?
Which Blade SSD should I go for? Any recommendation? Also, should I replace the Fusion’s HDD for an SSD like a Samsung EVO 970 or similar?
I see a lot of confusion regarding it and I am a bit lost.
I have upgraded HDD on old iMacs, MacBook Pros in the past but I know it's not a simple process when it comes to remove the logic board, but it can be done with some precautions.
Which are the parts I’m going to need to have the job done? Please could you list it. I don't want to open the iMac and realize that something is missing and not be able to finish the job.
Thanks for the help.
Update (06/20/2020)
Hi Dan.
Thank you very much for your help.
I was checking the link you post about SSD and it says it's not compatible with Imac 17.1
Do you have any idea where I can find a SSD compatible with my Imac ?
I am trying look for something at Ebay, preferable in Europe, but I didn't have too many options.
In case I choose the OWC Aura Pro X2, what would be the difference between them ?
I already have all the tools needed and adhesive strips that I bought before and never used. I would like to know if I will need any cable adapter so ?
Update (06/21/2020)
Here is some info about my system, so you can be sure about it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
9条评论
Then you'll need to stick with the Samsung SSPOLARIS SSD then in my first link ;-{
Thats all there is! Here's a useful link The Ultimate Guide to Apple’s Proprietary SSDs
完成的
I meant the first link you posted ( Samsung SSPolaris ) is not compatible with my Imac.
Would be any problem if I go for the OWC SSD ?
完成的
Sorry I posted the wrong link here's the correct one SSD Replacement Kit – iMac 27″ A1419 Late 2015
The OWC SSD is a no go!
完成的
Besides an used SSD I found this one on Ebay and he claims its compatible with my Imac ( https://www.ebay.com/itm/323984844157?ul... ). Can I trust this info ?
I also found this info ( https://beetstech.com/blog/apple-proprie... )
"All of the SSDs found in the Late 2015 iMacs are of the new PCIe 3.0 x4 variety, but the A1418 only supports a PCIe 2.0 x4 connection. The 27″ iMac, on the other hand, is the only device other than the 15″ MacBook Pro to support a PCIe 3.0 x4 connection. Both iMacs support the NVMe protocol though and can upgrade to later Gen. 5 SSDs for a big speed boost."
Every time I dig into it, I get more confused.
Dumb question but in the worst case scenario, if I don't find any new compatible Blade SSD, will the Imac work if you remove it ?
完成的
You are getting your self twisted up with bad info! The eBay link is for a Mac Mini not your system.
The A1418 designator covers a wide range of systems! Thats like saying all Ford pickups have the same engine. Which we know is not true!
So is this not what you want? SSD Replacement Kit – iMac 27″ A1419 Late 2015
You have a 27" system, correct?
Your system is in the A1418 series, correct?
Is your system a Late 2015, correct?
As you pointed out your system has a PCIe 3.0 x4 slot so a NVMe/PCIe 3.0 x4 SSD would be the correct SSD, correct?
So this must be the correct SSD is it not?
完成的
显示更多的4条评论
添加一条评论
3个答案
已选择的解决方案
Ideally you want a real Apple blade SSD, Go with at least a 512 GB Samsung SSPOLARIS (1 TB would be even better!) which is large enough to hold your OS & Apps with the remainder of the drive left unused for cache & virtual RAM as needed. Then just leave your HDD alone! So you’ll have the SSD be your boot drive and your current HDD as your data drive. If you do vids or music getting the larger SSD will allow you to use it as your work space of your current project then move it over to your HDD when done’
If that’s too expensive go with the OWC Aura Pro X2 SSD which will also work quite well in your system!
You should break the Fusion Drive set before you take the blade SSD out following this guide Split Your Fusion Drive Apart
Follow this guide to get to the blade SSD 27英寸 5K Retina 显示屏 iMac 固态硬盘SSD 更换
The needed tools are listed in the guide or you could get a fuller tool kit so you’ll be ready for your next project!
You will need this as well [关联产品丢失或禁用: IF174-005] as the tool you’ll need to get the display off is in the kit (you may want to set a second adhesive set just in case) and getting two sets of Plastic Cards will make taking off the display a lot easier!
Update (06/21/2020)
OK, sadly Apple designed the system with a custom PCIe interface so your options are limited!
I don’t buy parts off of eBay as there are 100% used even when they tell you otherwise! Apple controls its parts suppliers quite tightly so your only source for many parts is in the recycled parts market. Some parts are from parted out new systems! So don’t assume the dedicated parts supplier like BeetsTech doesn’t do this. Drop them an email or call them to get more info on the given part.
Even a used PCIe blade SSD is better than jumping to a much slower SATA SSD!
Last year I setup over 10 iMac systems using recycled PCIe SSD’s none of the owners had any issues. These are mostly students in the arts video and music production which are both very hard uses. So I’m not overly worried. Granted I verified the health of the drive before I installed it.
Maybe the better direction for you is to just get a replacement system which has a factory installed blade SSD (new or used) and then add in the second SATA drive in it or just use an external Thunderbolt drive which is much faster!
As an example I have a 2013 Mac Pro which has a 2 GB blade SSD and I have a SSD RAID drive which has four 2 TB drives for my data drive.
Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172图片
产品
Plastic Cards
$2.99
这个答案有帮助吗?
得分 1
添加一条评论
Hello
If I remove the blade SSD and leave that slot empty, can I use the computer from the SATA drive only?
Since it is so hard to find the correct SSD, I might just leave it out and swap the hard disk for a SSD instead. But will the iMac work like that?
Faan
这个答案有帮助吗?
得分 1
1条评论:
It is possible. I removed the Apple SSD from my iMac 27" 5K 2015 and exchanged the HDD with a Samsung SSD. I installed Big Sur via Internet Recovery on Samsung SSD and everything works fine.
完成的
添加一条评论
After some research I decided to go with a Samsung Evo Plus 2TB M2 SSD on my iMac, I just needed the M2 adapter.
Spend 450,00 EUR total ( SSD, Adapter, M2 enclosure, adhesive - I already had the tools, so no need to buy it ), instead of paying 600,0 EUR for the OWC SSD. So far, no regrets at all.
Split the Fusion Drive using another tutorial, because after Mohave the disks are converted to APFS ( https://medium.com/@ObjSal/split-fusion-... ).
It took some time to take the iMac apart and clean all the dust inside, specially at the Power Supply and Fan. Some parts on Ifix tutorial were a little bit different on my iMac ( 27 - Late 2015 ) but not that hard to figure it out, except the Power Supply, which has a hiden screw to remove the board.
Put it all back together, it took a little longer on the first start up and it seems to take longer to show the Apple logo, but in general start up process is a little faster with the Samsung M2 SSD over Apple SSD.
For 3 days I have never had any problem, but I did let the iMac hibernate, which seems to be the most common issue and haven't tried to recover from the internet and install boot camp.
I am getting up to 3300 mb/s read-write speed, so pretty happy with that.
If you are in the same situation I was, I can tell you to go all the way with the M2 SSD. Probably the Samsung Evo Pro would be better choice, but I am happy with the Evo Plus.
这个答案有帮助吗?
得分 0
1条评论:
Can you please tell me which M2 adapter you bought. It seems I can not find the right one working with the iMac 27" Late 2015 and not causing sleep problems or being too long for the iMac SSD slot.
完成的
添加一条评论
添加你的答案
saulobelter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,358
