跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
SSD drive in optical caddy?
Hi!
Just a quick question. A couple of years ago I replaced the internal HDD with a SSD which led to a spinning fan etc, so I installed a software app which have worked pretty good. Now I want to do it “right”, and I’ve read that if you install the SSD in a optical caddy, the fan won’t go nuts? Obviously I’m gonna reinstall the original HDD. So original HDD and a SSD in the optical caddy, match made in heaven? Best solution?
/Oscar
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You probably didn’t know you needed the OWC In-line Digital Thermal Sensor for iMac Late 2009 - Mid 2010 Hard Drive Upgrade.
Apple used a propriety heat sensor and if you change the hard drive you will get a run away fan, this sensor prevents that.
iMac Intel 21.5" and 27" (Late 2009-Mid 2010) SSD Temperature Sensor
https://eshop.macsales.com/item/OWC/DIDI...
UPDATE
iFixit EU Store
iMac Intel 27" Mid 2010 Dual Hard Drive Kit
https://eustore.ifixit.com/products/imac...
Add an SSD to your iMac with this cable. A temperature sensor for the SSD is included.图片
产品
$39.99
这个答案有帮助吗?
得分 1
10条评论:
Thanks for the answer. Yeah, I did knew that, but at that time I was satisfied with the fan control solution and I was happy saving a couple of bucks. I also live in Sweden so that thing wasn't easy to come by. But, if we return to the main question, is SSD in a optical caddy a better solution?
完成的
See the dual hard drive kit update. SSD with optical BUS is to slow.
完成的
@mayer This series has both SATA ports running SATA II (3.0 Gb/s) so it doesn't matter which port the SSD is sitting in.
完成的
@danj OK but why lose the optical drive when you don't have to?
完成的
This system only has two SATA ports unlike the the 2011 models which have three.
So its a bit of a toss up! What's important to the OP. Having a dual drive config (HDD & SSD) or a single drive and the optical drive.
完成的
显示更多的5条评论
添加一条评论
添加你的答案
OscarPetré 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 261
