跳转到主内容
The Durango was marketed as a sturdy truck-based SUV designed to hold up to seven passengers and tow up to 7,500 lb (3,400 kg) when properly equipped.
19 个问题 查看全部
Ill ecm for 5.2 work on 5.9
Will 5.9 using ecm for 5.2 mak engine skip misfire and run rough?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It might but they have the same firing order. Check for codes. Turn on the ignition on and off and back on 3 times quickly and it will flash out trouble codes. Record the check engine light as this happens and we can see if it has trouble codes and what they are.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Little 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 70
