跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
Battery + - diffrent
ipad air battery needed replacement. Ordered model number 1478 as that is what it is.
battery came 1478…only trouble is when I looked at old battery and new ..positive and negative terminals are opposite ways around????
looked at few other batterys online and there all the same as new one. Say for example + -……where as old one is -+ ……can anybody tell me why this is please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you.
You are quite correct the original is stamped wrong.
Did not wish to install it once saw the diffre ce just incase but upon checking new battery it is 100% as should be.
完成的
添加一条评论
1个答案
已选择的解决方案
That doesn’t sound right. The best thing to do if you or someone you know has a multimeter is check the polarity to be sure as the +&- might have been stamped incorrectly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dionne Davies 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 179
