跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
PS4 Pro “checking system storage” never completes.
Anytime my PS4 gets unplugged, or I lose power while it’s on, I basically lose all my stuff. It comes back up when I turn it back on and tries “check system storage.” It gets to 26% and stops every time. Then I get the prompt to download an update file onto a USB device and so forth. Had to do that numerous times in the past month, downloading all my games back, signing back in and everything. Anybody got any idea what the issue is? Bad hard drive? SSD? HDD? I don’t know much about tech, but I’ve been googling for some time now and I appears nobody has the same issue as me. I’ve seen others have similar issues and get told it’s their SSD, but I don’t have the kind of money to assume that’s the issue and buy one and it not work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Wesley,
When you unplug your PS4, do you shut it down as it should (power off option instead stand by mode). You always should turn it off completely before you unplug it.
Testing:
  • Turn it off completely, unplug it, does it still need to “check the system storage” ?
  • When you put it in Stand by mode, does everything works good or is still telling you to check the storage?
  • Is it possible to test with another harddrive (perhaps to test with a harddrive from an old laptop)?
这个答案有帮助吗?
得分 1
2条评论:
Yes, I usually turn it off correctly.
When I do that and unplug it, then turn it back on it doesn’t do the system storage check. Only when it’s been turned off by unplugging or losing power. I pretty often get frozen screens and then I have to forcefully turn it off by unplugging.
Standby mode also doesn’t make me check the storage.
I could possibly try a difference hard drive.
完成的
Okay. Could be the harddrive which is causing the "Frozen screens". I would test it, with another drive. If the system is not frozen, just completely shut it down before you unplug it :).
完成的
添加一条评论
Ok so my name is Riley and my ps4 screen froze while I was at the home menu and I couldn't do anything like my ps4 co troller could not control anything and I began to worry so the only thing I could do was to forcefully unplug it and then replug it up and turn it on and when I did it would be in safe mode and would always only go up to 26% in checking storage status and idk why it's doing this. Could it be a bad HDD ? ALL IK IS THAT it was asking for me to plug my usb to my controller and to turn it on by pressing the ps button and then when I did that it went on where it said to cancel or ok by it saying to plug up a usb so all I did was click cancel and then it turned off and then I turned it back on and it did the same thing over and over again like it's some kinda loop and I googled at how to fix this but no one seem to have the same problem besides this person right here. But dude did you figure out at how to fix this and if you did please tell me.
这个答案有帮助吗?
得分 0
1条评论:
So I tested my laptop hard drive on it and everything has been working perfectly fine since, and I’m just keeping that hard drive in, so I’m assuming that my hard drive was the issue. Not quite sure if that would also be your problem also
完成的
添加一条评论
添加你的答案
Wesley Burns 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 44
过去 30 天: 152
总计 15,395
