跳转到主内容
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
What problem with my floor lamp?
I just bought a floor lamp few days ago and I installed it like the instructions but I when I put a bulb and plugged it in, it’s not working. I don’t understand why.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Did you verify that you have power coming out of the outlet? Plug in a hairdryer or something to verify that the outlet has power. Some outlets are switched and don't have power until they are turned on.
Update (06/10/2020)
Did you try a different light bulb? Can we get a picture of the lamp?
这个答案有帮助吗?
得分 0
1条评论:
Yes, I already verify it, but it still not working. I'm so upset and don't know why
完成的
添加一条评论
Hi,
What is the make and model number of the floor lamp?
Verify that you have followed the installation instructions etc and if so and it still doesn’t work, since it is new, return it for a replacement or refund.
这个答案有帮助吗?
得分 0
2条评论:
Hi
I don't know the model number, but it calls Alice traditional floor lamp. I installed it like the instructions but it still not working, and I don't know the reason. I don't know that I can return it or not because I bought it from Walmart online. And in the app said my item was canceled but in fact I still receive it. And if I want to return it, it has to have the return button, but I don’t see it cause it said canceled.
完成的
@Bella Pham
Does it look like this?
Strange as I cannot find it listed with Walmart.
You may have to contact Walmart direct and talk to them about the problem
完成的
添加一条评论
添加你的答案
Bella Pham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 232
