跳转到主内容
Samsung 的无线耳机。和 Galaxy S10 手机一起发布于 2019 年 3 月。
42 个问题 查看全部
Buds ran through the washer and wont charge the left side.
My buds got ran through the washer. i opened up the buds and cleaned the contacts with rubbing alcohol and blew dried it. They both work, but the left side wont charge.. everything still works on the left side but it wont charge. is there a replacement part i can buy? i thought it might of been the battery so i replaced the battery and still wont charge. Any help is appreciated. thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It probably has corrosion under the charging ic. You could pull the chip off and clean it and reball it and put back on. You could also try cleaning the board in a sonic cleaner with Branson ec cleaner and dropping it in alcohol and blowing all of the moisture and alcohol off. Or you could take it to a repair shop and have them repair it. Or last option you could buy a new set of them. Unfortunately it probably will cost more to repair them than to replace them. If you have access to a sonic cleaner and the chemical to do it that's what I would try.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 362
