跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
399 个问题 查看全部
iPhone XS earspeaker not working after screen replacement
Just recently replaced a iPhone XS screen and pretty sure before the earspeaker worked now after the screen replacement it doesn’t, Face ID proximity sensor front camera etc all work just not the earspeaker unsure why
Any help would be great
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You could have damaged the solder joints on the cable. You can replace the the earpiece speaker. But my guess is a bad connection to the motherboard. Remove that connector and make sure all of the pins are straight and clean the connector with alcohol and a qtip and a soft brush. I actually had the same problem with xs max and it was the connection.
Update (06/08/2020)
Yes that fixed the issue. I would first check the solder joints on the cable and earpiece speaker and then check the connection to the motherboard and make sure the pins aren't damaged and clean it and hopefully that will solve your problems.
这个答案有帮助吗?
得分 0
1条评论:
Did that fix the issue?
完成的
添加一条评论
添加你的答案
Kris Madhav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 2,134
