跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Will installing PCIe SSD slow down fan if HDD damaged?
Hi there :)
I got iMac 5K 2014 27” which had HDD but removed as died.
Now because no HDD fan is full on as thermal sensor in HDD is missing - would it fix it installing PCIe SSD (original Apple or NVMe with adapter)?
All I know all iMacs originally shipped with PCIe SSD only (without HDD) fans were working fans as normal.
Do they have “special” different firmware or just if iMac detected removed HDD but installed PCIe SSD automatically “cure” itself
Thank You for help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
A blade SSD model would have a jumper on the logic board to disable the HDD sensor.
Your options are just put in a replacement SATA 3.5” HDD or a 2.5” SSD with the OWC in-line sensor and call it a day.
Or, put in the correct Apple or OWC blade SSD into the PCIe/NVMe blade drive slot to gain the most performance.
I personally don’t like using the M.2 SSD’s with their funky adapters in iMac’s given how difficult they are to get to it’s just not wise! To put in bluntly, I have a very full drawer of dead M.2 SSD’s and adapters I’ve pulled out of Mac systems! The quality of the drive and the adapters as well as the way Apple setup the custom interface these M.2 SSD’s just can’t emulate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 80
