跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
when I press rt, my character moves forwards
When I press/hold the RT button, my character moves forwards which makes it really hard to play games like Overwatch.
I have a black powerA wired xbox one controller with LED’s on the rims, i forgot the actual name, please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Same i have the exact same controller (spectre power A) and this also annoying when im playing minecraft have you managed to fix it i need help..?
完成的
添加一条评论
4个答案
已选择的解决方案
Hi!
Open up the controller and clean it from the inside. Also the input board.. I’m not sure how it looks like inside the PowerA controller, and I think it will be difficult to find replacement parts for that one too..
这个答案有帮助吗?
得分 1
4条评论:
Thanks for the advice, but ive never really opened up a controller i will try though
Do i have to turn it off?
完成的
Your welcome! Yes, the controller needs to be turned off. The controller needs to be unplugged.
完成的
So all I need to do is open the controller and clean it? What parts should i clean, all of it?
完成的
Yes. Check for dust and remove it. The parts you should clean: Thumbsticks, input board (or ribbon circuit board).
完成的
添加一条评论
what do i clean it with
这个答案有帮助吗?
得分 0
1条评论:
Alcohol wipes.
完成的
添加一条评论
i have exactly the same controller and the same issue :(
这个答案有帮助吗?
得分 0
添加一条评论
These controllars can be a breeze to clean. You can find how-to-videos on YOUTUBE on how to clean or repair your model of controller. With a Power A You just need a precision screwdriver set, a bottle of isopropyl alcohol (aka Rubbing Alcohol), and some electronic cleaning swabs. And something to organize your screws. Some rubber mats are used for circuit boards and other assorted electronics and have little places to organize and keep your screws in place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
H C 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 38
总计 6,924
