跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
Machine not powering on - logic board issue?
The machine itself will not power on. I have tried an SMC reset, but it had no effect. I’ve tried multiple chargers in all available ports, and there is no change. I’ve disconnected the battery and attempted to power on with the charger connected, but there is no response. Attached is an image of the voltage being sent from the charger. It would seem that the machine is not drawing enough voltage to power on properly. The main question is, is this most likely a problem with the logic board? Or is it possible replacing the battery could resolve the issue? I do not have a separate battery available for testing.
Note also that there are no signs of liquid damage.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
This is likely a Board level issue (because i think the RAM, CPU, and SSD are soldered on most Macbook, Macbook Air, and Macbook Pro models.) and thus you need to unfortunately replace the Logic Board. I saw in the pictures that the Macbook is opened, was it like this before it stopped working?
这个答案有帮助吗?
得分 2
2条评论:
The problem was present before removing the bottom plate. We took the bottom plate off to investigate.
完成的
Ok, so that means it rules out a dust-related issue because the machine was closed. Does the MacBook show anything on its primary display?
完成的
添加一条评论
Most likely a board issue. Macs tend to be able to boot without a battery installed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zach 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 937
