跳转到主内容
加入维修社区 - 创建账户
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
Screen developing large haze section or moisture cloud.
I have noticed on my Thunderbolt Display today a blur over the screen when in use that is visible as a grey cloud when the screen is black. I’ve never seen this issue before and live in an area that isn't humid in any particular way.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I think you have a simple problem! Basically dust or dirt has collected on the backside of the cover glass and/or the display its self.
Follow this guide to pull off the cover glass, use a dry micro cloth dust off the inside surface, then using some window cleaner and a fresh micro cloth spray the cloth and wipe down the cover glass surfaces. The LCD display should just be dusted as it has coatings on it the cleaner will either damage or just make a mess and/or streaks!
Here’s the guide you’ll need to follow Apple Thunderbolt Display LCD Replacement following Step 1
这个答案有帮助吗?
得分 2
5条评论:
Hey Dan, I dont expect this is the problem given that the haze has disappeared overnight.
完成的
Thats the moisture in the air collecting on the dust! You should look at getting a de-humidifier to dry out the room.
完成的
@danj Did this work? My monitor developed the same exact problem today. It has been raining a lot and the temp dropped quickly today. I ran the monitor for quite a while while working out and it was near raining out.
完成的
@barty10101 Andrew, Did this work? My monitor developed the same exact problem today. It has been raining a lot and the temp dropped quickly today. I ran the monitor for quite a while while working out and it was near raining out.
完成的
@Charles Soechting - I would follow the steps I outlined as well as get a dehumidifier. The dusty surfaces will collect the moisture. Think how snow crystals are formed they form around a partial of dust. This in some ways is not any different. While you can still collect moisture on a clean cold mirror the dust just amplify’s the effect.
完成的
添加一条评论
添加你的答案
Andrew Bartram 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 2,619
