HP Pavilion 15-p Hard Drive Replacement
Thanks Alot.
I’d like to buy exactly this hard disk but I can’t find it on the internet. I want to change the hard disk board cause I want to safe the datas and I didn’t made any backup. I know… stupid.
The days of a raw PCB swap died with the mid 2000’s Maxtor DiamondCrash* drives after they were discontinued :-(. You need to transfer the ROM on these newer drives, and make sure your donor is a 100% match. PCB swaps are dead.
*IT slang for DiamondMax before Seagate bought Maxtor. This is like how we call the IBM DeskStar drives "DeathStar" due to their high fail rate, and tendency to eat the magnetic coating on the glass platters.
These "DeathStar" drives are a total De-Ja-Vu today since the Seagate Rosewood drives do the SAME THING, with the SAME CAUSE OF FAILURE.
The main problem isn't the PCB and ROM transfer, though. The issue is the preamp and headstack need to be a match, or at least very, very, very close at the absolute bare minimum. A lot of drives just do not match because they use what is available at the time, and even 2 drives from the same batch may end up being too different. 1 day between IDENTICAL batches is ENOUGH to cause a mismatch in these new drives!!! DO NOT MESS WITH THE DRIVE - SEND IT TO A PROFESSIONAL OR YOU COULD FATALLY RUIN ANY CHANCE YOU HAD! You can't do this one at home.
这个答案有帮助吗?
You should share the image of the hard drive for a better solution. Anyhow This hard drive should work with your Pavilion 15-p.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 298
4条评论
Hi @valentinehiner
What actually happened? do you have a picture to share?
Older drives can be a challenge to find.... even you replace i think you also need to transplant the ROM chip over to the doner board.
由 Augustine 完成的
You can try HP EG001200JWJNQ (https://www.allhdd.com/hp-eg001200jwjnq-...) It's a good replacement of HP Pavilion 15-p hard drive.
由 maka homes 完成的
Even boards on the same model/version HDD are not always exactly the same. I am going to bet, you just learned a hard lesson of why backup is important.
由 bill 完成的
Hi @Josh Roberts
What I believe he is talking about is replacing thel drive's circuit board. That is why the same model is wanted for data recovery.
由 mike 完成的
