跳转到主内容
加入维修社区 - 创建账户
ASUS Q536F 发布于 2019 年 5 月。 这是一款二合一电脑,相比同类竞品,无论日常办公还是游戏都具备出色的性价比。
Back Pannel Won't Come Off
There is something holding my pack pannel on and I can't figure out how to take it off. From the outside it looks like a circle made of the same material as the panel. I can pry it open and look inside and it seems to be a screw. I can't move it as there is nowhere to place the screwdriver. It may be on the otherside underneath a keycap but from what it looks like it doesn't like up with any keys. Pressing down on it does nothing, I can't rotate the back pannel off either. Anyone know what this is and how to get it off?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Hi,
Did you look under the “feet” to see if there are any screws there, holding the cover on?
完成的
I can pry the whole thing off, its just that part in the middle that is holding onto it.
完成的
what screwdriver did you use to open the screws?
完成的
Maybe the screw is under the keyboard. Take out keyboard and have a look.
完成的
https://www.youtube.com/watch?v=WW30dcvq... this model should be the same frame. if it is holding in a obviously no bottom screw area you need to pop the plastic off from the top the keyboard and remove those screws to expose the screws that you need to get at
完成的
添加一条评论
1个答案
已选择的解决方案
This is most likely a cover hiding a screw in the middle of a back panel. You can use a very small flathead screwdriver (e.g. flathead 1) to pry off the screw cover and get access to the screw head.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Braxton Biggers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 1,091
