跳转到主内容
加入维修社区 - 创建账户
After installing New HD won't start
After installing a new HD in MBP it's dead. Won't start. Connected to power cable and power light on cable is on but computer will not start. What else can I do now?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
Hi, We need some more information to help you.Which MBP do you have? What are the last three numbers of the serial number? What drive did you install and what color light on the power cable? Why did you replace the drive?
完成的
Pre Unibody vintage 2006. Last 3: VWW. Installed WD 250 GB Scorpio Blue. Old drive died.
完成的
Apple MacBook Pro "Core Duo" 2.0 15" Specs
Identifiers: MacBook Pro - MA464LL/A* - MacBookPro1,1 - A1150 - N/A
完成的
添加一条评论
1个答案
已选择的解决方案
Reconnect your top-case to logic board cable.
这个答案有帮助吗?
得分 3
10条评论:
Please explain further
完成的
It sounds to me like your unit is not getting a power on signal. The most common problem with this when a computer has been worked on the the cable that connects from the top-case to the logic board. See step #10 on this guide: MacBook Pro 15" Core Duo Model A1150 Upper Case Cable Replacement
完成的
this could be my problem. The original video I watched talked about prying it up and maybe I separated the "plug" from the board. I'm not really sure as I can't tell from the photos what it's suppose to look like. Should I have seen pins on the bottom of the cable? Did it "plug" into the board or just come in contact?
完成的
It's to hard to explain what kind of plug it is ( a rectangle socket) , just push it down with your thumb. If you leaned the keyboard up against the screen it probably pulled on the backside of this plug and lifted it out. It probably has some kapton tape helping to hold it in place.
完成的
I may have pulled the whole plug assembly off the motherboard. I only pulled at the yellow tape but maybe due to age the solder separated. Now what do I do?
完成的
显示更多的5条评论
添加一条评论
添加你的答案
economy10 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 465
