跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
L button doesn't work at all, R button doesn't work most of the time
Hello everyone, I have a CTR-001 3DS with broken L and R buttons, with the R button rarely working. I have another 3DS that might not be recoverable that I would be willing to use for parts. I don't have a soldering iron so I was wondering if I could switch out the buttons without one. My charge port is also bad but I saw that I would need a soldering iron to fix that. Many thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Giamo,
The L and R buttons are connected with flex cables to the motherboard.
You can replace them both easy without soldering.
Link for the part: https://www.aliexpress.com/item/40000370...
Note: For the charging port, you need to de-solder the old one and solder the new one in, or replace the motherboard (but this will be expensive).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pepper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 96
