跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Half the screen of my iPhone is completely black with colored lines
Hi, I replaced the screen on my iPhone 6 and now half the screen is black and there are vertical colored lines and the other half is really glitchy and like is flickering really fast. Touch screen and everything else seem to work, just the display. I would appreciate any advice . Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Ok thank you! I will try it out and see if it works
完成的
添加一条评论
1个答案
已选择的解决方案
It sounds like a bad connection. Take a magnifying glass and make sure the connector is not damaged. Then clean it with a qtip and alcohol and a soft brush. Make sure you disconnect the battery before unhooking the screen connectors. There is a possibility that you have a defective screen.
这个答案有帮助吗?
得分 1
1条评论:
Allen is right. This sounds like a connection problem.
完成的
添加一条评论
添加你的答案
Anshul Verma 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 45
