跳转到主内容
Repair guides and support for vacuums by Dyson, including upright, canister, and handheld vacuums.
424 个问题 查看全部
Why is my Dyson DC24 only working on rotating brush?
Halfway through using my DC24 Multi Room, 2 years old, and it suddenly cuts out. Only the brush bar rotation works when the hoover is tilted back for floor use. Checked for blockages, cleaned filters etc. Still only working on brush bar, not main unit.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If I’m understanding your problem correctly, you are saying that when you turn the vacuum on, nothing happens. Then, when you tilt the handle back, the brush bar turns but nothing else. If this understanding is correct, it means your main motor isn’t working. There is a separate brush bar motor, which is working.
Check out this video: https://www.youtube.com/watch?v=pBmvbz4I...
It shows the disassembly of the DC24 to the removal of the main motor. Pay particular attention starting at 8:00, where he disassembles the brush bar switch and the power harness to the main motor. Make sure nothing has come loose or obvious signs of damage. Then, at 21:00 he starts to remove the motor from the ball.
This video shows installing a replacement main motor: https://www.youtube.com/watch?v=jztEPw7u...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
davidedwards93 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 44
总计 1,533
