跳转到主内容
The IBM ThinkPad 600E was released in 1998 as part of a series of laptops produced by IBM.
5 个问题 查看全部
I can not get the fan/heat sink assembly out of this laptop.
The fan assembly feels loose however it wont come out. Its like the fan is swollen and stuck to the underlying assembly some how? Am i missing something ? I believe all the screws have been removed..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @rabond ,
Here’s the hardware maintenance manual for the laptop.
Go to p.83-84 to view the necessary pre-requisite steps and then the procedure to remove the CPU card and the fan.
Hopefully this may help you to remove the fan
If the fan requires replacing, on p.109 Item #27 you will find the part number for the fan. Search online using the part number only will give results for suppliers of the part.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Randy Bond 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 8
总计 75
