跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 Touch ID Not Scanning/Spazzing Touch
I just did a battery replacement on an iPhone 7. Very clean, didn’t touch anything I didn’t need to, and was very gentile with the device. After putting together, it said Touch ID Not Available and the home button stopped working. So I took it apart again, disconnected the screen connectors, and then air blew the connectors. After doing this, the home button works and there is no “Touch ID Not Available” pop up. Yet when trying to read a fingerprint on the lock screen, the phone spazzes in and out of Reachability, and when entering the Touch ID settings in Touch ID and Passcode settings, it allows me to add a fingerprint and tells me that I am pressing too hard on the screen. I tried hard rebooting and even replacing the Taptic Engine but am at a total loss of what the issue could be. Here are pictures of everything that may help someone more knowledgeable than me help diagnose this issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You need to check the home button cable that goes from the screen to the motherboard. Check under some sort of magnification for a small tear in the flex, it usually occurs at the 90 degree bend.
这个答案有帮助吗?
得分 2
2条评论:
I thought this too and checked it but didn’t notice anything wrong or torn? See the 3rd picture. Not saying that’s not the issue but I would hope that I would see something there if it was what was wrong
完成的
Some tears are microscopic I usually put them under a microscope to check but you will need to try another screen. If it is still the same it would point to the home button assembly.
完成的
添加一条评论
添加你的答案
Logan Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 107
