跳转到主内容
加入维修社区 - 创建账户
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
Why does the fire stick cause TV problem?
When I plug the fire stick in to the TV it causes the TV to turn on and off every few minutes. There is no problems with the TV when y remove the stick and I can use the HDMI sockets for other TV boxes with out a problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @cabopino ,
Are you using it with the supplied power adapter connected or the USB cable?
If the USB cable, try using the power adapter instead. Perhaps the TV cannot supply enough power from its’ USB port for the Firestick and the Firestick is cycling on and off. Just a thought.
这个答案有帮助吗?
得分 1
1条评论:
Have tried both power supplies and plugged the stick directly into the TV in both slots.
完成的
添加一条评论
添加你的答案
Barry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,503
