跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
Primer button is cracked
Is the weed wacker getting to much air
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
How old is the machine? Do you leave gas in it in long periods of time? Do you use e10 fuel? I would simply just replace the bulb. You can get them cheap on Amazon or in a big box store for a little more. Usually a few screws you need to take off ( you may need to take off other stuff as a well depending on your model. Realize these bulbs are just thin tube like material. Try to use ethanol free premix. Big box stores or select few stations ( if any) in your area will have some. Ethanol is small engines worst nightmare. Wrecks havok on everything. Start with replacing bulb, simple YouTube search and 5 minutes you'll be done. Use ethanol free fuel /premix. The primer bulb should not have thay much pressure. If you've done any maintance make sure you put the lines on correctly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henry Hysell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 765
