跳转到主内容
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
318 个问题 查看全部
Front fan assembly (IO and CPU_MEM) not spinning
Machine has been overheating. Tests verified the IO and CPU_MEM fans in the front fan assembly are not spinning (they stay at 0 RPM during a fan test, no visible movement). After removing the fan assembly I noticed the cable connection to the port on the logic board was kind of smushed and bent. It looks like someone tried to force the fan assembly into place. I was able to fully seat the cable in the port, but am still not getting any fan spin. I’ve tried a separate front fan assembly and cable, fully seated in the port on the logic board, and the fans still do not spin during tests. My hunch is that the port on the logic board was damaged due to past improper installation of the front fan assembly, but there’s no visible damage to the port. Has anyone had a similar issue or advice to offer? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Have you tested for voltage at the connector on the motherboard?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 65
