跳转到主内容
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
33 个问题 查看全部
Truck won’t turn over, makes no sound, Gears shift without brake pedal
I was moving my truck from one part of my yard to the other. As I put in park I heard a pop and then my truck died. It will not turn over but I can put it in the on position and listen to the radio. I am also able to shift gears without having the brake pedal pressed.
I have replaced the starter, ignition switch, ignition lock cylinder, and the neutral safety switch.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It died while you were driving it. Does it try to start/crank over? If it does did you check for fuel and spark? If it doesn't crank over, did you check if the engine will spin over? Take a breaker bar and the correct socket and put it on the center bolt inside the crankshaft pulley and see if the engine will spin over buy hand. Let me know what you find and we can go from there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JGD04 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 4
总计 64
