跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Why is my home button always down?
The iPad keeps taking pictures when I try to turn off the iPad, it keep double clicking when I only press the home button once, the iPad keeps signaling for Siri, and it keeps pulling up random tabs and jumping between apps
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Does it look like the home button is physically pushed down into the screen assembly? It sounds like the bracket for home button might have broken loose from the screen assembly. It might also have something sticky on the home button to cause it to stick. You are going to have to take the screen off and check what is the problem. You can change the home button but you will lose touch Id. The factory home button is matched to the motherboard so an aftermarket home button will work but touch Id won't. I would try to fix the original home button first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mary Rohde 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 24
