跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
Green display on turn off, clearing after 10-15mins
I have had my thunderbolt display for a while and no issues until one day it seems to click, and the green appeared.
After about 10-15mins it disappears and the screen is back to normal.
The green is all over with what looks like some image persistence at the sides.
I have stripped the display back but could see anything obvious then wasn’t sure what to look for. I gave everything a clean with a blower, a long shot but no joy…
Any advice welcome.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try cleaning the connections with a qtip and alcohol and a soft brush, there might be corrosion just from the humidity in the air.
Update (05/21/2020)
If you open it up it should have a connection where you can change the screen.it should be internal. I use Rubbing alcohol as high of a percent of alcohol.
这个答案有帮助吗?
得分 1
2条评论:
Hi Allan, thanks for coming back. Which connections? And what alcohol is best?
完成的
Done and unfortunately no change...
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 43
