跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
No audio No Vibrate
I replaced the battery and lightening-headphone Jack. Worked for awhile then No speaker output for incoming ringtone. No vibration either.
Screen shows caller ID upon receiving a call and the Volume controls are active onscreen just as they should be. The Mute switch toggles as it should and also appears on the screen.
I get ringtones and notifications if I’m linked to my Nyne Bluetooth speaker or my car Sony deck
I have sound if my earbuds are plugged in as well
Are the audio and vibrate lines contained on the same buss? Help me out
Marcus
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Allan
I’m new to the forum so I hope you see this. I posted an answer vs. comment. Newbie forum Jedi
完成的
添加一条评论
2个答案
It's either the connections for the charging port or a defective charging port. The tapic engine and speaker are powered through the charging port connector/lightning connector.
这个答案有帮助吗?
得分 0
添加一条评论
Sweet. I had a strong hunch that one of the flex cable/connector buses that were separated during disassembly didn’t seat correctly and lost continuity.
I recall also also having difficulty with reassembling a few injection molded structural support parts (Tiny!!) That fit next to the charging port. Had an Itty bitty gasket and I don’t recall the rest other than it being totally frustrating and cheeky
Don’t know if that affected my current sitrep.
So does cracking it back open and reseating connectors then opcheck sound about right?
Many suggestions on links for visual references of the target (buss) connectors?
Appreciate ya Brother
marcus
这个答案有帮助吗?
得分 0
2条评论:
I would try checking the connections for damaged pins with a magnifying glass and then clean the the connector with a qtip and alcohol and a soft brush
完成的
The same issue happened to me. I removed the speaker, scratched the contacts under it, then reinstalled it. It seems to have fixed it.
完成的
添加一条评论
添加你的答案
MARK KESLER 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 138
