跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Water Damaged SSD Recovery? Anything
So this is a niche problem, because most people would give up by now. But I had some important stuff on this phone and I’d do just about anything for it back. So heres the deal:
Its water damaged, very water damaged, brought it to a shop and he said there was a lot of water in it then, and that most likely I tried to power it on with water inside and it shocked the system.
In a computer, if other systems are shot, then you can just take out the hard drive and plug it into an operational computer, and the data would be there. I understand that the SSD is affixed to another part of the internals quite tightly. BUT, is it possible to transfer the SSD to another iphone(or anything else), and be able to recover the data? I feel like it must be, just rather difficult.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It is possible to transfer the NAND to another device but this would be the last resort as not only will you need to transfer the NAND but also the CPU, SD ram, EEPROM etc. A reputable repairer will first try and get your phone to boot as it is the easiest and most cost-effective way of retrieving data.
这个答案有帮助吗?
得分 4
2条评论:
Which is why I recommend ipad rehab. You can do what is necessary unless they get bad advice and someone tries to repair or get data from the phone and they don't know what they are doing. They you can completely lose the data and it is not coming out of the phone.
完成的
@barriphone Frank asked about transferring the SSD to another phone. I was only answering his question.
完成的
添加一条评论
Send it to jessa at iPad rehab ipadrehab.com they have a flat fee and I believe that they don't charge you unless they get the data. She had a phone sent in from nova Scotia that was dropped in a lake and was sent to her 11 months later and she was able to get all of the data. I would send it to her first, people not knowing what they are doing can damage the phone were it's impossible to retrieve data. She was one of the people to start doing this work about 10 years ago and is one of the best in the world.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 534
