跳转到主内容
Blue question mark near drive
Hi, 2 days ago my ssd ejected from my pc and I don't know how. The drive cannot be found in drive manger or device manager, and only place where i can see it is in file explorer and it has a blue question mark near it. I cannot acces properties, but i do have an option to scan it with windows defender and when i choose that it shows me all the folders in the drive but i can't access them nor scan them. I have family photos on that drive and I don't want to lose them.
Things to know:
5 people use this pc everyday
It's not a bad pc
The ssd was near full
On this ssd windows aren't running they are on a different one
Somwhere i saw to acces hidden devices, but i can't find the drive
People also say to change drive letter, but I can't because I can't find it
Edit: sorry for bad English and thanks in advance
Really hope i won't lose the data
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I DID IT!!!
Device manager\view\show hidden devices
Click disk drives again and find it (it should be greyed out)
Right click on it a choose uninstall device
Turn off your pc and then plug out the power cable
Open up your pc
Disconnect and reconnect your drive
Turn it on again and it should be fixed
这个答案有帮助吗?
得分 4
7条评论:
Glad that it’s resolved! Sorry for the late response (just saw your comment below at this moment).
完成的
You responded and for that thank you.
完成的
Thank you so much! I was dealing with this issue for a few hours 11:00pm to 1:00am since achi wouldn't work with my sata hard drive but i went back from raid to achi and it works! (:
完成的
The files that in missing drive d if i do that it will be deleted or it stays?
完成的
U just save my life, tysm<3
完成的
显示更多的2条评论
添加一条评论
Hi!
Did you already checked “Disk Management” ? If yes, what kind of information do you get from there? You can also assign or change the drive letter here!
What is the brand of the SSD? Please download and run the manufacture it’s software (for Samsung it’s Samsung Magician as example) and see what the application tells you.
这个答案有帮助吗?
得分 0
1条评论:
I checked disk management and there is my other ssd, an external hard drive on which i download movies,2 disk 0 partitions and a wd smartware virtual disk that came with the external drive. I'll attach a photo so you can see. None of those are my missing drive because it has 320GB and these have less or more. The missing one is labeled F:
The SSD is WD3200BEVT and the software i have is wd smartware and i can't find the missing disk there, but i don't think it's up to date cause it's only version 1.2.0.8
完成的
添加一条评论
添加你的答案
Infa 将永远感激不已
浏览统计数据:
过去 24 小时: 14
过去 7 天: 58
过去 30 天: 242
总计 21,134
