跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
How to know if Power Supply is okay?
The computer doesn't power on. It only shows a solid green light in LED#1
The power supply makes tick noises and the noises change when I press the power button.
I would like to know how can I test it with a multimeter? I'm planning on buying a new MB because this one has a blown part but I don't want to buy a new MB and have a bad PSU kill it.
Here is a video to check out the sounds and the burned part: https://www.youtube.com/watch?v=LK7_qJPd...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
A ticking noise is a coil or transformer in the power supply.
I would first replace the power supply before trying a new logic board.
这个答案有帮助吗?
得分 1
11条评论:
I will record a video of the sound and post it on YouTube. I'll post the link here. Give me about an hour or two.
完成的
@pigoath - No need, I've had a few tickers across my bench ;-}
完成的
I will be uploading the video anyways. I would really appreciate if you could check it out. I want to know how to test the PSU with a multimeter to know if it's giving me proper voltage or if the problem is the MB.
By the way, is it normal for a PSU to make ticking sounds? I guess not?
完成的
No, the power supply doesn't tick! You have a bad coil or transformer within the power supply assembly.
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Pigoath 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 196
