跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Phone acting up after replacing a few parts
so i replaced the battery, speaker and front camera/proximity sensor and now my phone is acting crazy. It randomly shuts down, no vibration, no sound, no wifi, and cant hear anyone when i call. What did i do?I followed the guides and was as careful as i would be with a clients machine. I work at a computer repair shop so this is kind of embarrassing…. Luckily i knew enough to test it before i put it all back together.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Did you have to pry the battery out?
这个答案有帮助吗?
得分 0
5条评论:
no. I pulled the tabs and it came out nicely.
完成的
I know iPhone 7 had major issues from people carrying them around in their front and rear pockets that caused the phones to twist and bend/bow or be dropped hard and you do minor work and they have issues start showing up.
完成的
@barriphone How exactly?
完成的
If you carry the phone in your back pocket and sit on it with pants that are skin tight it will bend the phone and twist it same in the front pocket. I had a iPhone X that the case was bowed to the point that I was afraid the screen would not go back onto it. The motherboard is screwed down to the case and if the case bends or flexes and twists so does the board and so do the contacts that hold the split board together.
完成的
@barriphone Oh i never did that
完成的
添加一条评论
Did you try putting the original components back in the phone? Why did you replace the front camera assembly? Does this phone show any sings of previous damage? Do the volume buttons work?
这个答案有帮助吗?
得分 0
1条评论:
i tried putting the original speaker back and it wasnt working. The volume buttons dont work because the sound doesnt work now. and yes it has some scratches on the body but otherwise has worked fine.
I got the phone used 2 years ago and it has been working great. However the left speaker stopped working last year some time and i ordered the speaker but never got around to replacing it. And the proximity sensor never really worked but it didnt really start bothering me until recently. As for the battery it had noticably shorter life so i decided to replace that too. So i replaced it all last night and here i am without a properly working phone.
完成的
添加一条评论
添加你的答案
Anthony Fieno 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 51
