跳转到主内容
加入维修社区 - 创建账户
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
Battery and force touch sensor replacement
I replaced the battery and force touch sensor on my Apple Watch series 1. Before closing everything up, I tried to turn it on, but there is no response. I went back through and disconnected and reconnected everything again, and double checked that they were seeded correctly. Still nothing. What else can I try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you test the battery? Check the battery connection. Try cleaning the connections with alcohol and a soft brush. See if that helps.
这个答案有帮助吗?
得分 0
6条评论:
I did not test the battery. How would I do that? I have double checked all connections, and cleaned all connections with rubbing alcohol.
完成的
Get a volt meter and check for voltage
完成的
Trying. Not getting anything on the volt meter.
完成的
Put the voltage meter on dc power and volts. If you aren't getting anything your battery might need charging. Or you may have a defective battery
完成的
plugged the charger into an ipad charger block, which gave more power to jump charge it. Seems to be working now.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Janessa Campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 134
