跳转到主内容
The Samsung Galaxy A10 is an android smartphone developed by Samsung Electronics. It was released in March 2019.
71 个问题 查看全部
I dropped my phone in water
my phone has been dropped in water as a prank by my friends. now, the phone’s screen is black, I dont, know if I can remove the battery or not.
It works, it’s just that the screen is black considering i get the vibrations for notifications
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like you damaged the screen. You will need to replace the screen with frame. You will need to take the back cover off and remove the Phillips screws and take the mid frame off (this is not the same frame for the screen). The you can unhook the battery. You can check the board for corrosion and clean it with alcohol and a soft brush. Ifixit has some repair videos and you can also find more videos on YouTube. You will also need a precut adhesive for the back cover. I hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Issacpe28 2.0 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 408
