跳转到主内容
TI-84 Plus calculator support.
38 个问题 查看全部
Why is a row of buttons on my TI 84 plus not working?
I’ve got a TI 84 Plus in good condition; the only problem is that not all of the buttons work. Specifically the buttons that aren’t working are the “log”, “7”, ”8”, “9”, “x (multiply)”, and the Up button on the keypad. The first 5 of these buttons are in a row straight across the keypad. I’ve tried cleaning the key mat and the big green motherboard, still nothing. There was some yellow gunk on the board when I cleaned, there might have been a battery leak at some point maybe? Any help would be very much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If a whole row is dead then it’s likely the issue is a broken trace on the PCB. If you have a multimeter then you can probably pinpoint the place(s) where it’s broken and repair it if you know how to solder. There are many tutorials out there for fixing a broken trace, here is one I found. Let me know if you have any other questions!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Micah Yoder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 685
