跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Display problem on MacBook Pro 2012 mid
Hello everyone. I have a macbook pro 2012 mid and recently had a problem on the screen. At the time of updating or turning it off and on again I cannot work with the equipment unless I connect it to my screen through an HDMI cable. Does anyone else have this problem? Do you know if it has repair? I enclose some photos to better appreciate the problem. I hope you can help me. Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
1个答案
已选择的解决方案
By any chance did you run the machine with a damaged LVDS cable? If you have been having cable issues and you ignored it, you likely fried the board :-(. The problem is the cables short out enough and it takes out the board. You may get lucky, but it often takes the board out with it.
If this is fresh, STOP USING THE MACHINE and replace the LVDS cable while you have time! It never ends well to wait until it gets worse. This does require display disassembly which is not an easy job, but it can be done. Follow this guide to remove the assembly and then this video to change the cable. It isn’t easy.
这个答案有帮助吗?
得分 1
1条评论:
Thanks mate. I will search a LVDS cable.
完成的
添加一条评论
添加你的答案
Felix Miranda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 262
