跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
Screen flickers and goes black randomly
My customer has an iPhone XS Max. Screen started to flicker then randomly display goes black and comes back. Works for a few days or so then happens again. No visible damage present. Tried a new screen genuine and aftermarket and none of them even turned the display on. (The phone still turns on but cannot swipe to turn off)
so far only the customer’s original screen is showing something randomly. Pictures below. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hi .
Did you solve the issue? I have the same problem and I don’t see any solution for solve this . I check the YouTube video like Allan Barr suggest but no lucky . Thank you
完成的
添加一条评论
3个答案
Was the phone dropped? Does they carry the phone in their front or rear pocket? Let me know the answers please.
Update (05/10/2020)
It sounds like the contacts on the outside of the board are losing contact or possibly have contacts pulled off of the motherboard. It has a split board and if you drop it hard enough or in the right spot. Or if you bend or twist the phone it caused this issue. This happens from putting the phone in your pocket. I have a iPhone xs max with a bow in it from someone who keeps the phone in their back pocket. I would watch a few videos on YouTube from jessa at ipad rehab ipadrehab.com or Jason from sts telecom ststelecom.com it will give you an idea. Look up videos for a iPhone X, XS, XS MAX they basically use the same board. If you send it to someone I would recommend one of them. I hope my information helps
这个答案有帮助吗?
得分 0
1条评论:
They didn’t mention a drop but who doesn’t drop their phone lol. There was no physical sign of damage on the screen or display. Couldn’t tell you where they keep it is that important? How so?
完成的
添加一条评论
Hi I also have this same issue with my iPhone XS. However this issue started occurring after it had been in water. I kept it turned off for a week after i did my best to dry it as it had very weird green screen flicker, which doesn’t occur anymore. The only issue that still has is the Face ID being disabled and the screen glitching like the example above every day or two randomly
这个答案有帮助吗?
得分 0
添加一条评论
Hello ,
Just an update , in my case , I change the screen and everything works as should for the last couple of month .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amir A 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 36
总计 2,101
