跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
No functions work unless screen is off
It's a weird issue I have here.
My touch screen, home button, power button, literally everything does not work unless the screen is off. So if the phone is powered off the power button works fine, if the screen is off the home button works fine. What do I do? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would try a hard reset, press and hold the power button and home button at the same time and hold them until the apple logo comes up. Try that and see if that will work.
这个答案有帮助吗?
得分 0
4条评论:
Hey, update. Pretty sure it's the screen somehow shorting it out. I put it on another 6s and it now has the same symptoms.
完成的
Did you put the screen back on the other phone and see if it works on it?
完成的
I've only got that screen between the 2. But the same thing is happening on both phones when I use the same screen.
完成的
Then it sounds like it needs a new screen if it does the same thing on both phones.
完成的
添加一条评论
添加你的答案
Jakob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
