跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
iPhone 3GS not able to charge it keeps connecting an disconnecting
i have a problem i have a iphone wall charger when i connect it to the wall charger it connects an keeps disconnecting after every movment the phone makes an now it wont even connect to my computer it says usb dont regonized or anything
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
first place to check is the dock connector port.. this error message is usually because you have dirt/pocket lint etc blocking your pins from connecting with the USB cord. Use a toothpick or similar to get rid of anything you can see, don't just blindly pick away or you'll cause damage. If that doesn't work then you may need to replace the dock connector. Click on the guides/parts link under the iphone photo.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ismael candelaria 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,415
