跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Boot Looping after screen replacement.
so basically i’ve narrowed it down to the speaker thingy with the 4 pins on the back. if i remove that and only that the phone beets up. i have no idea what to do.
Edit#1 I have tried booting without the speaker, but while pressing the proximity sensor down into place and it didn’t boot. so it must be the sensor. But if the sensor isnt being pressed down it works. What do i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
(THIS MAY NOT BE THE TYPE OF ANSWER YOU’RE LOOKING FOR)
I basically grinded down the metal selfie camera thing that holds it in place, so that it literally only covers the camera and not the speaker. I
only put in the bottom 2 screws on the speaker.
I also had to sand off the top right corner of the speaker to remove the screw hole so that when I attach the camera mount it doesn't tighten the speaker.
I agree I probably could have done a better job at fixing it correctly and I still don't know what the root of the issue is, but incase anyone else has this exact issue this worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
If it works without front camera (FCAM) cable plugged in and no pins look damaged on the board you need to replace the FCAM flex cable and that will fix the problem.
iPhone 8 前置摄像头和感应器更换
iPhone 8 Front Camera and Sensor Cable
Replace a front-facing camera or proximity sensor compatible with the iPhone 8. Part #821-01185, 821-01133.图片
产品
$13.99
这个答案有帮助吗?
得分 1
添加一条评论
I think you have to check if the flex cable isn’t broken otherwise you need a new proximity sensor .
这个答案有帮助吗?
得分 0
添加一条评论
You know you can buy a new screen with the earpiece speaker and proximity sensor already installed for around 30 to 40 dollars fixez.com all of have a do is change the home button and it should work fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shawn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 109
