跳转到主内容
A range of desktops aimed at the mainstream consumer market, spec-wise situated between the Inspiron and XPS lines released in 2009.
55 个问题 查看全部
Laptop not turning on, but the quickplay button lights on.
My Dell Studio 14 does not turn on. when I pressed the power button, the quickplay button lights on for a few seconds and nothing happens after that. there are no sounds at all. is it related to motherboard failure??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You did not specify the model number of your unit so I've provided a link to the 1435 service manual. I hope that is correct.
http://support.dell.com/support/edocs/sy...
这个答案有帮助吗?
得分 2
添加一条评论
Try to turn on your laptop without the battery on (only with the plug adaptor).
If this doesn't work, it is probably a hardware issue (although more inspection is needed before reaching this conclusion).
这个答案有帮助吗?
得分 0
3条评论:
I've tried. i even tried the upside-down trick but it didn't work.
thank you.
完成的
What is the make and model of your laptop?
完成的
mine is dell studio 14.
完成的
添加一条评论
添加你的答案
Ran John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,147
