跳转到主内容
加入维修社区 - 创建账户
2015款 Nintendo 3DS XL,也被称为新 Nintendo 3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
3DS randomly shuts off
So I’ve had this for a few years now(New Nintendo 3DS XL) but have shelved it since I’ve gotten a Switch. It’s literally been put away for about 2 years now but a few days ago I decided to use it again to play some old games. Today is when my issue started occurring.
My system is in good condition and I properly took care of it. Today I was playing a game and closed my system and put it in sleep mode to come back to it. When I opened it back up the system was shut off. I thought it was just dead so I charged it but even after putting it on the charger it wouldnt turn on. I decided to leave it charging and no matter how much i pressed the power button it wouldn’t turn on. So I took the battery in and out and kept pressing the power button and it decided to turn on after that for some reason. The system seemed fine and it indicated that the battery was fully charged so I decided to start playing again. About 5-10 minutes into playing it randomly shuts off again.
After multiple attempts off doing the same thing again(pressing the power button) the system decides it wants to turn on again and it does. I’m playing fine and then it completely shuts off. On a separate occasion the Power light on the system stayed on but the screens went completely black. Any idea what the issue could be? I was thinking something could be loose inside but I remembered I literally haven’t touched this thing for a while so I don’t think that could be the issue but I’m clueless with this kind of stuff. Is it simply the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It may be caused by a faulty battery. If someone from your family or friends have the same model, you can try using their battery and check if it works. Or you can buy a new replacement battery. It’s up to you which option will you choose.
Try that and if won’t work, let us know so we can troubleshoot it further.
这个答案有帮助吗?
得分 1
3条评论:
I am having the sam3e problem, but my battery works fine. I can't get past the first screen without it making a loud pop and restarting.
完成的
If there's a popping sound there is a short in the console. The most common problems are the ribbon connector components. The 3ds models have a self test when turning on and if there is a problem with the connection like the screen ribbon cable it will fail the test and shut off
完成的
@Peter Perez Yes i have the same problem and my ribbon cable is exposed.
完成的
添加一条评论
添加你的答案
Beemo 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 49
过去 30 天: 190
总计 5,409
