跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone X Screen replacement
Hi, I have 2 iPhone X’s and My first one has a broken screen/ LCD with black spots already (its the one that I’m using). And my second iPhone X is Icloud locked, but the screen is working fine. I would like to put the working screen of the 2nd iPhone into my 1st iPhone . should I swap everything including the cameras? and should I reprogram the display? or should I just switch it instantly? Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You only need to swap the display assembly between the devices. In order to maintain FaceID, you’ll need to keep the corresponding ear speaker assemblies with their original devices as they are tied to the specific board. Keep the ear speaker for the icloud locked board to that device and keep the ear speaker to the one you use. You’ll lose truetone unless you have the tool to copy the serial number but keep in mind you don’t need any tools to program the transferred display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Enzo Lubi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 160
