跳转到主内容
Successor to the PowerShot G7 X, the Mark II was released as Canon's flagship model in 2016.
19 个问题 查看全部
camera says "memory card locked"
My memory card has the switch in correct position as i can view pictures on a computer and on the camera screen, however it says Memory card locked the whole time and wont let me take pictures because of this? please help - Thank you. Lollu
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi! Have you solved this problem?
完成的
on the sd card there is a lock switch if it is down flick it up and it should work because i have had this problem before
完成的
添加一条评论
2个答案
已选择的解决方案
If the lock switch is in the open position, it usually means the flash is in a permanent read-only state. When the lifetime of the flash is close to being used up, this is a safety feature to preserve the data as reading doesn't do much harm to the card, if any at all. They allow this as a means to move the data, at most. Be glad it acted this way, since a lot of cheap cards which do not self lock tend to fail and take out whatever is on the card. Having to buy a card on short notice is far from ideal sure but I want a chance to save what's on it.
If you want to try and see if it can be fixed, backup the card to a PC, and then format it in the camera and see. In most cases, the flash is end of life and it will fail as it's a firmware level lock.
这个答案有帮助吗?
得分 3
1条评论:
Thank you very much!
完成的
添加一条评论
Hi,
There is manual lock option on Memory card used in Camera; please see the picture and try to solve the issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lollu 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 42
过去 30 天: 150
总计 3,436
