跳转到主内容
加入维修社区 - 创建账户
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Random Black Screen Appearing
2013 Macbook Pro, 16 gig memory, 256 SSD Hard Drive. It worked fine for several months. Then randomly started going to a completely black screen. The keyboard still lit up, and the Apple logo on the cover is still lit.
Have checked screen saver, auto screen power off, reset SMC and PRAM, ran fan diagnostics, checked for overheated using temp diagnostics, have completely erased and re-installed Catalina.
After a hard shutdown, the screen comes back on and may go a few minutes or a few hours before doing it again. If the computer is turned off for a full day, then it will not happen for several hours, before starting the same inconsistent black screen. It does not seem to be related to any specific software.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
What is the size of your system? 13" or 15"
完成的
I'm sorry. It's 15" Retina.
完成的
Let's check the battery and the charger. Install this gem of an app CoconutBattery with the charger plugged in take a snapshot of the apps main window and post it here for us to see {在已经存在的问题里加入图片]
完成的
Screenshot is in the post.
完成的
添加一条评论
1个答案
The Battery is getting up there! Just shy of 600 cycles of the 1000 lifespan. Even still its not at a point of failing.
This appears to be a deeper logic board issue with one of the current sense lines. It will need to be looked at by someone with the skills to debug the logic board. Or, your other option is replace the logic board.
这个答案有帮助吗?
得分 0
1条评论:
Hey Dan,
Thanks for your input.
I’m actually hoping the answer by Mike Sims I just found way down at the bottom of this page may be the fix:
MacBook Pro 15 inch Late 2013 suddenly turns off
As other users have mentioned, it does not do it when reinstalling the OS and some posts I've seen around the net say it started happening to them after upgrading to High Sierra or later OS.
Anyway, I’ll see how the trick mentioned above works. Worst case, I’ll have to consider hardware repair.
Thanks much!
完成的
添加一条评论
添加你的答案
Robert Jacobson Jr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 383
