跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Home Button Pairing Functionality
Hello guys,
I know the home button loses Touch ID if I swap the button, but will it still work as a home button?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
No it will not work. You will need to purchase a universal home button for the return function to work.
这个答案有帮助吗?
得分 1
2条评论:
What do you mean by universal home button?
完成的
@solsanchor If you just replace it with another home button from a different iPhone 8 it will not do anything it will just be cosmetic.
A universal home button will function the same as original except touch ID
• Press home button one time, back to home
• Press twice in succession, bring up the background running program
• Press home button for longer time, wake up Siri
• Press power button and home button at the same time, make screen capture
完成的
添加一条评论
Yes, if you change the home button it will still work as a home button but will lose the touch i’d. Make sure to buy a home button that doesn't use wifi. They make a exact replacement that doesn't use wifi. I believe they are around 15 dollars or so but don't quote me on the price I haven't checked in a while. I just checked and You can buy one from ifixit for 25 dollars. It will fit a iPhone 7/7 plus 8/8 plus. That will take care of the problem and it will work normally. I know this works as I have replaced a few that were damaged.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sol TT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 143
