跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
burnt my balls off
Hello engineers I’m a newbie with a simple question for you. I am trying to learn how to micro-solder and was practicing on an i-phone 7 logic board, attempting to remove the audio i.c. Probably too complicated for training, but after i finally got the i.c. off I noticed several of the balls on what I guess would be the base were missing. They looked silver as opposed to the copper colored ones on the i.c. I tried to apply solder thinking the solder would be attracted to the spot where it should go but no luck
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The iPhone 7 audio IC has a few NC pads that usually come off with the chip. These are not required and are not connected to any circuit that is why they come off. Check the ones that came off are not NC pads.
Blue pads are NC
这个答案有帮助吗?
得分 1
1条评论:
Great info, thanks again
完成的
添加一条评论
that is called ripped pads on the motherboard, and its bad, if you have schematics, you can check what the damaged pads are for. maybe you can bridge them. you have to practice more, since this happens when you don’t use the correct amount of air/heat/flux. this all depends on the calibration and brand of your hot air station. keep practicing
这个答案有帮助吗?
得分 0
2条评论:
Thanks so much and after doing lots of research and thinking about it I discovered one mistake that hasnt been helping me. I bought a cheaper chinese hot air station, Zeny 832D which is ok for me now, but I have been setting the temps for farenheit but my station is set for celcius so my temps havent been correct
完成的
Awesome, I didnt know that, how would I know the difference tho?
完成的
添加一条评论
添加你的答案
mikespring1972 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 9
总计 66
